Results 1 to 7 of 7
    Jul 2015
    Kosova
    Default RNS 1TO 035 680 B
    sofware loading error (010301)
    any help i try to SW 5238_josi
    number7hd's Avatar
    Dec 2013
    download sw 4020 and make downgrade. sw 5238 is not for "B"
    If my solution helped You - do not forget to THANKS !!!
    Jul 2015
    Kosova
    Quote Originally Posted by number7hd View Post
    i try with 1100 but still same prblem
    Aug 2008
    make sure cd/dvd is good quality and burn at lowest speed you can
    Jul 2015
    Kosova
    Quote Originally Posted by tango View Post
    i try with fix swl version and i have this situation
    The DVD of SW 110 is SONY DVD -R Accucore and i burn it with lowest speed but same problem
    Jul 2015
    Kosova
    I try to put some different SWL 4020 i try 1300 i try 4100 bu i have this image Untitled.jpg i put the SWL 1100 it change the fault and nw is
    Error - EcuOrder.txt-Error reading HW Vers
    Any advice
    May 2018
    hi i have one the same problem did you get yours fixed cheers
