Abs coding can be calculated.
Or simply change the vin in the new cluster, to the original vin.
And close VCDS abs session, after any longcoding insert, accepted, or not.
6R0 907 379 BE
ESP8.2I
old coding 230248E34376028BC42A12E2C2D1408111700
i put a set in cluster ecu,after all went to 000 on abs as per normal ,tried to copy original back wont copy !
any other coding i can try ?
Abrites ,full package
Carprog
Dajavue
Zedbull
orange 5
Tango
Vag-com
Vag Tacho
Vag Dash can
Vag Can pro
Magpro 2 X17/ FLEX
VVDI PROG /MB PROG
pay the price ...go original always works better......
ok what about the immo and ecu ?
Carprog
Dajavue
Zedbull
orange 5
Tango
Vag-com
Vag Tacho
Vag Dash can
Vag Can pro
Magpro 2 X17/ FLEX
VVDI PROG /MB PROG
will give the vin if it helps
vwvzzz6rzdy099781
Carprog
Dajavue
Zedbull
orange 5
Tango
Vag-com
Vag Tacho
Vag Dash can
Vag Can pro
Magpro 2 X17/ FLEX
VVDI PROG /MB PROG
all sorted
Carprog
Dajavue
Zedbull
orange 5
Tango
Vag-com
Vag Tacho
Vag Dash can
Vag Can pro
Magpro 2 X17/ FLEX
VVDI PROG /MB PROG
