Results 1 to 3 of 3
    negative2323's Avatar
    Dec 2015
    Europe
    Default Vag edc17c46 ori cfgb 03L906018NC
    Car: vw
    Model:Passat
    Year:2013
    Ecu Sw: 03L906018NC
    Ecu hw: 03L907309AE
    TransmissionSG 6
    Ecu is dead no possibility read flash+eeprom.
    Used ecu from donor car has same Hw, but sw is 03L906018QB. The immo is ok, but there is no coding option.
    Need ori dump with 03L906018NC sw.
    May be 03L906018NT would be an option. Also I have frf of 03L906018NC, but cant to convert it bin. Dear dk mates need your help.
    Wbr Maxi
    Oct 2015
    Hi, NC software is for Alltrack (4WD DSG). Maybe NT (2WD DSG) is working. But think about matching powerclass. I don't know if they are the same in NC and NT.
    If you have frf for NC and IMMO OK you could flash it with VW tools. Maybe at the dealer if you don't have. After that I would check correct coding in VCDS.
    VCP can also flash frf but I have no experience how good it works with ECU.
    Dec 2015
    Europe
    Quote Originally Posted by DreamDancer View Post
    Thank you all. Problem is solved.. Car is alltrack deg 4wd..
    Wbr Maxi
