Zgemma H5.2c
Results 1 to 13 of 13
Thread: Zgemma H5.2c
    Default Zgemma H5.2tc
    Just bought this box it has openatv 6 image on.
    Having a look can't see many images for this model.
    What's a good image for this box with auto boughet
    On?
    Will older zgemma box images work for this model as it's quite new don't that many images for it.
    DK Veteran vorlon2257's Avatar
    Sep 2011
    Vorlon Homeworld
    Aleady has the best image on it. Connect it to the internet and do a sofrware upgrade.... blue button / software update / ok on remote once updates are found hit green button on remote to upgrade then follow on screen instructions.
    Be aware though, although it has the open-atv 6.0 image on it, it could say that your image is outta date, you'll be given the option to update or not.
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
  4. The Following User Says Thank You to smirnoff_rules For This Useful Post:
    super jumbe (24th June, 2017)
    is their no blackhole images available for this box yet thanks for the links some links to the images are dead.
    digicon's Avatar
    I am afraid you wont get Blackhole for this receiver as that team work exclusively for Vu+ so only write images for there receivers
    Hadron's Avatar
    Nov 2012
    E. London
    I'm thinking of getting an H5.2TC soon.
    I'll probably try the ipab image.
    Quote Originally Posted by Hadron View Post
    great box loads of flash memory i put ipab image on it got 2 sets of bouquets sly and virmin.
    much better then the dreamboxes no green screens no slow delaying channel changes.
  9. The Following User Says Thank You to tab99_uk For This Useful Post:
    Hadron (15th June, 2017)
  10. #8
    DK Veteran lincsat's Avatar
    Jun 2008
    Prefer ViX myself, just personal preference though most OE are pretty similar.
  11. #9
    getting problems with this box installed the ipab image worked ok for 2 days and then went to boot so flashed it again same thing happed again went to boot again.
    tried a few more images all stuck on boot only one that will work is ipab one but gets stuck on boot after a few days.
  12. #10
    Hadron's Avatar
    Nov 2012
    E. London
    I don't know if the H5 is the same, so it may not be relevant to your problem, but I've noticed that the sticky plastic covering the lid of one of my previous Zgemmas (H2) also covered all of the ventilation slots. I've removed the plastic to ensure good heat flow.
  13. #11
    yeah i removed them all.
  14. #12
    Use Whooshbuild it's easily and automatically updated over internet. Good IPTV and Auto Bouquet features
  15. #13
    its been ok since i posted on this thread will see if it goes in to boot again.
