Which machine do you use to program the key?
SK Auto (20th June, 2017)
Try and report
SK Auto (16th June, 2017)
Thanks for response
I am using Mercedes Instrument,first time i have a problem.
One of my friends send me a keys calculated from Abrites to test and none of them work
I have been told only Key calculated as rom 57 from Zed Full will work.
If some one have a Zed Full and calculate me a keys i will appreciate.
You cannot use Avdi calculation for MI application. If you did not solved car, on Monday I will calculate it with MI so you can compare dumps, but I guess you have other problem as MI is one of best tools ever made for Mercedes............
Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
doctore (19th June, 2017)
Thanks Gavra for your help i have the keis from MI and Aleksei confirm they are correct.
I am looking to test a Zed Full key calculated as rom 57
if they not working i have a suspicious maybe the Flash on EZS get corrupt for same reason .I am use smok to read and i didn't have a problem so far.
Write this key and start the car. I modified hex dump for you. Try and report. Press THX and REP...
New_Key051_N5.rar
how may keys have this car?
is it all lost keys or spare key?
did you try others track?
Did you try the keydumo from me ??
are you sure your key psw is correct?
i have make some B-Class with and without keys
with MI and others tools without any problem.
pass: 04 E4 BD 07 06 91 43 67
VIN ending in 953
your keys:
When I did the calculation with Abrites, he told me that there was no key programmed in that car.
However, that same file is used with SKC and detects 2 keys in use.
I think the problem is in the calculation that makes Abrites because it has already happened to me on two or three occasions that it does not work with reading SMOK.
To fix it, I recommend it. In ABRITES, use the option DAS MANAGER, READ EZS and in the option PASSWORD, you put this 04 E4 BD 07 06 91 43 67 and give you to generate keys.
Automatically, it should recognize the keys and programmed and it will let you make new keys in V.51
