Results 1 to 14 of 14
    Aug 2011
    Default Golf IV 1.6 16V Marelli 4MV EGR Off
    Hi, I will be grateful if anyone could make EGR off for me.
    Golf IV 1.6 16V
    Marelli 4MV
    BCB
    77kW
    2003
    flash_036906034DR_ori.rar
    regards
    Jul 2011
    hi send dtc.
    Jun 2017
    london
    where the dtc code for egr
    Aug 2011
    Hi, DTCs :
    3 Faults Found:
    16786 - EGR System
    P0402 - 35-00 - Excessive Flow
    17851 - Potentiometer for EGR (G212)
    P1443 - 35-00 - Signal too Low
    17848 - EGR Valve (N18)
    P1440 - 35-00 - Open Circuit
    regards
    Aug 2011
    Noone can make it ?
    pike's Avatar
    Sep 2013
    Exclamation Golf IV 1.6 16V Marelli 4MV EGR Off
    Hi.
    You can try this file.
  7. The Following 2 Users Say Thank You to pike For This Useful Post:
    pipina (22nd June, 2017), stanislav georgiev (21st June, 2017)
    Romania
    Default have same pproblem with same ecu.
    Here is my flash content.Can somebody remove me egr dtc?
    her is the error.The egr is new, cleaned everything.....
    16785 - EGR System
    P0401 - 35-00 - Insufficient Flow
    my ecu is 036906034DR marelli iaw4mv.dr
    thanks.
    pike's Avatar
    Sep 2013
    Quote Originally Posted by illestibor View Post
    16785 - EGR System
    thanks.
    Hi.
    Try...
  10. The Following User Says Thank You to pike For This Useful Post:
    illestibor (22nd June, 2017)
  11. #9
    Mar 2013
    Europe
    How do you read ecu?
    Kess?
    Ktag?
  12. #10
    Aug 2011
    Hi, unfortunatly don't work corect. There is no DTC in diagnose but light is ON.
    regards
  13. The Following User Says Thank You to pipina For This Useful Post:
    pike (23rd June, 2017)
  14. #11
    Aug 2011
    I read it with FGtechnology.
  15. The Following User Says Thank You to pipina For This Useful Post:
    bersch8688 (23rd June, 2017)
  16. #12
    Aug 2011
    Problem solved.
  17. #13
    pike's Avatar
    Sep 2013
    Quote Originally Posted by pipina View Post
    Problem solved.
    ok, welcome.
  18. #14
    Romania
    For me not work.I read flash separate in programator, must calculate checksum before write back, but after have
    Internal Room error and the car won't start.Must write back original.
