open ecu on both sides that is the save way.
Hello
I have an ECU Edc17cp45 from BMW to make and I need to know the measures in which I have to drill the ECU.
I have to do 2 guajeros, one for boot and one for the GPT cables but I do not know the distance that I have to do.
Does anyone have that info?
Thank you
The best way of being grateful is touching the button thank
) who open that ecu is crazy......is multistrat pcb...one bad move and you can shot yourself....
pulsar2000 (22nd June, 2017), smirnoff_rules (20th June, 2017)
aem (20th June, 2017), beltronics (21st June, 2017), morgano (21st June, 2017)
What about metal particles that you can't get out when they drop inside
there is no particles inside.is not drilled to the end.....is drilled untill you can force piece to broke....in this way you can put it back with seal after read write.
if is not ok like this you can buy special tool from magic motorsport is only 260 usd
gedas8899 (22nd June, 2017), mariusica_boy (20th June, 2017), teerak2uk (21st June, 2017)
What tool did you use for drill,and aprox.distance?Thanks
Sent from my SM-G920F using Tapatalk
you have two choices in the morning: go back to bed and continue dreaming, or you get up to make your dreams come true
easy going
https://www.youtube.com/watch?v=mUOrKiZzIL0
https://www.youtube.com/watch?v=5HZYpiEwGaI
use THANKS button
whats the name of a drill with a hole in the middle ?
Holesaw .
no not them its looks like a drill bit but has a hole in the centre
Hmm never seen one a drill with a hole in the middle can't drill as there is no cutting part in the middle
Annular cutters
https://advancedrills.com/annular-cutters/
beltronics (22nd June, 2017), smirnoff_rules (22nd June, 2017), teerak2uk (22nd June, 2017)
