Yes, still behind the vent.
I guess that you know this, H types immoboxes can not be reset.
You will need to repace it, with a virgin box.
Or one with atleast a master key added box.
Only H smart boxes can be done by obd for now.
rola1971 (21st June, 2017)
It is mainly the heating unit that is not giving you room.
I am not sure if it is bolted, from the engine space side.
I use some airwedges before to gain some space.
If the owner does not mind:
Cut the wires, and just place a used box somewere else.
Synch ecu 30 min. And job done.
Synch tool Toyota.pngThis is the special Toyota tool needed.
Turn ignition on, with master key.
Connect (bridge) short obd position 13 to 4.
Leave this for just over 30 mininutes.
Then remove the special tool, and turn ignition off.
Then start the car, job done.
doctore (21st June, 2017), DOUGLASDL (29th July, 2017), dyzio (22nd June, 2017), Faraday (22nd June, 2017), key4man (22nd June, 2017), lush29 (21st June, 2017), rola1971 (21st June, 2017), Siham (22nd June, 2017), super jumbe (27th May, 2018), triak88 (25th May, 2018), ucokseparoh (23rd June, 2017), Weasel3 (22nd June, 2017)
Funny rob
How you reset ecu?
where to buy another used box?
junkyard?
internet?
Special reset tool - clone from china work ok?
rob h (25th May, 2018)
