Audi TT 2001 key light flashing
Results 1 to 7 of 7
    Apr 2015
    Default Audi TT 2001 key light flashing
    Hi guys, I coded keys with super vag and tried with tango also, key light
    flashes but car starts. I had the same problem before with VW caddy but
    when i loaded the dump on tango detected the problem and fixed it.
    Audi TT 2001 VIN: TRUZZZ8NZ11025882 Magneti marelli cluster with mcu 5h55w.
    p1et's Avatar
    Oct 2013
    This is common problem when programming key with some devices. I use VAG-Tacho to program and then it's okay.
    In a van down by the river
    Agreed with p1et.
    TCode gave me this issue many times on 2005 and earlier cars. My solution - reset battery - erase keys - try again. I think it is something with cycling the keys at the end. Usually can get it no problem sometimes just need a few programming attempts. unless your software is causing the problem but I doubt it.
    Apr 2015
    Thanks guys for the advice, Ill try again on Monday whn the car comes back.
    the original key of the car has an id48 magic I and Im using ID48 magic 2 for the second key
    could that be the problem?
    yugo45's Avatar
    For this car best way use VCDS and pin, it will be perfect, Other tool may cause problems always.
  6. The Following User Says Thank You to yugo45 For This Useful Post:
    sirjay (26th June, 2017)
    Apr 2015
    Quote Originally Posted by yugo45 View Post
    thank you yugo will try vcds and report
    Apr 2015
    Quote Originally Posted by sirjay View Post
    thanks yugo i coded chip with VCDS, and no flashing key light now
  9. The Following User Says Thank You to sirjay For This Useful Post:
    yugo45 (27th June, 2017)
