Results 1 to 14 of 14
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Default motorcycle transponders
    Hi guys.
    Have question about bikes transponders.
    In my case 4d60 dst80
    I bought some 4d60 . Seller claims originals.
    when i scan with tango its sais 4d60 80bit ir 40bit mode.
    It should be like this or its must be just 80 bin not 40 bit mode?
    Aug 2016
    They will read as 80bit once coded to vehicle
    Sent from my HTC One M9 using Tapatalk
  3. The Following User Says Thank You to Sergio101 For This Useful Post:
    drugowaz (22nd June, 2017)
    gepakg's Avatar
    Serbia
    this transponders arrive in 40 bit mode,but if you need for some models 80 bit also can be switch to it
    regards Gepa
    Quote Originally Posted by drugowaz View Post
    Hi guys.
  5. The Following User Says Thank You to gepakg For This Useful Post:
  6. #4
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Switch manualy. Or automaticly itself when programing ?
    gepakg's Avatar
    Serbia
    you can switch it manually or script/module automatically if that model need it in 80 bit mode
    regards Gepa
  8. The Following User Says Thank You to gepakg For This Useful Post:
  9. #6
    drugowaz's Avatar
    Mar 2015
    Lithuania
    how to do in manual way?
  10. #7
    gepakg's Avatar
    Serbia
    with what tool you want it?
    regards Gepa
  11. #8
    drugowaz's Avatar
    Mar 2015
    Lithuania
    Say tango ar vvdi2
  12. #9
    gepakg's Avatar
    Serbia
    write on page 30 next bytes 08 46 and you will get it in 80 bit mode
    regards Gepa
    Say tango ar vvdi2
  13. The Following User Says Thank You to gepakg For This Useful Post:
    drugowaz (27th June, 2017)
  14. #10
    drugowaz's Avatar
    Mar 2015
    Lithuania
    in tango i see only 1 to 4 pg
    sel addr p1
    user1 p2
    serial/man p3
    encr key p4
  15. #11
    drugowaz's Avatar
    Mar 2015
    Lithuania
    photo of chip
  16. #12
    gepakg's Avatar
    Serbia
    friend it is 4D-40bit meny,you must go to DST+ for manage 80bit transponders
    please switch in your mind what exactly you want not to ask for trivial things...mt friendly opinion
    regards Gepa
    photo of chip
  17. #13
    drugowaz's Avatar
    Mar 2015
    Lithuania
    ok. done in pg 30 wrote 08 46 . got notice that tango will loose comunication with transponder if write. when wrote it dont read transponder sais "volatile reading. try changr key position. and still in 40 mode.
  18. #14
    drugowaz's Avatar
    Mar 2015
    Lithuania
    than i tried backwards you said.
    wrote 46 08 and it worked. now chip is 80 bit mode.
    and not under dst+ option. but under dst80 . when i trien to change on dst+ i get error about comunication loss with chip and etc.
