peugeot & citroen activation - Page 3
Page 3 of 55 FirstFirst 123456781353 ... LastLast
Results 31 to 45 of 823
  1. #31
    Thanks for the code Patrian, it worked great. but what about the code for the Citroen service box?
    I would appreciate if you could give it to me.
    Best regards
    Kid
  2. #32
    Please activation code for
    Peugeot 08.2009, the language is Serbian, and the country is Serbia
    installation code QB6IOAAA.
    Thank you!!!
  3. #33
    Oct 2008
    Greece
    Thumbs up
    Quote Originally Posted by Kid View Post
    Best regards
    Kid
    Citroen (RO): DAL7-E6EH-QU56-3RDW
    Citroen (GB): RCWL-4K4L-AHT4-WVRA
    Good Luck!
  4. #34
    Oct 2008
    Greece
    Thumbs up
    Quote Originally Posted by komshija View Post
    Thank you!!!
    Peugeot: 35QK-MVLO-WDFA-XJ2T (D-Kao!)
    Enjoy!
  5. #35
    Sep 2010
    hi patrian i need activation code for peugeot sedre 08/2009
    coutry:argentina
    languaje:spanish
    code:F5APMAAA
    gracias
  6. #36
    Member maarksparky's Avatar
    Jun 2008
    Quote Originally Posted by nikko_123 View Post
    coutry:argentina
    languaje:spanish
    code:F5APMAAA
    gracias
    There you go mate,
    Argentina: 66CJ-SVAO-MJYB-FPMF
    if you have any problem with it then try
    Spain: DVVU-4CIW-UL2S-2A2D
    need any help, please let us know.. cheers
  7. #37
    Patrian,
    Thank You very much! (Ευχάριστό πάρα πολύ)
  8. #38
    Patrian, can you please help me with installation of peugeot backup? I have installed everything with activation that you have gave me without any problems but now when i start peugeot docbackup it starts and when i get into the browser i only can seen VIN field and when i type VIN inside the field it says that it is unknown, also there are no cars to select like it should have. I will attach picture so that you can see. If you have any sugestion please tell me.
    Thank you
    Best regards
    Voislav
  9. #39
    Oct 2008
    Greece
    Wink
    Thank you
    Best regards
    Voislav
    It seems that you have problem with some options in your Registry and about your Language.....
    So, you can try this:
    1. Close BOTH application if they running & also from your Taskbar!
    2. Use Regedit, edit in your Registry & change this key string from BackupAC (Citroen) or BackupAP (Peugeot) like this:
    AppLocale from local => en_GB (Example about English Language...)
    3. Restart your computer and now run your applications and you should been:
    Feedback IF still you have problem.....
    Good Luck!
    Regards!
  10. #40
    Patrian, thank you very much. You were right, that did a trick. It works nice now.
    Once again Thank You!
  11. #41
    Jun 2009
    Scotland
    Hi i need the activation code for sedre 08 2009
    country GB
    Language English
    code Q6N7CAAA
  12. #42
    DK Veteran scotcruz's Avatar
    Sep 2010
    S C O T L A N D
    Quote Originally Posted by tfi016304 View Post
    country GB
    Language English
    code Q6N7CAAA
    Your activation code is:
    DMXZ-CYLR-4JCB-GNHE
    Please click "Thanks" once its worked for you !
  13. #43
    Dear Friends:
    Somebody can help me??? I would like to know if someone can share with me activation code for Citroen Sedre DocBackup 2010.
    My personal code is : U3MZJAAA language: Spanish
    Thanks in advance!!!!!!!!!!!!
  14. #44
    Oct 2008
    Greece
    Thumbs up
    Quote Originally Posted by olpesa View Post
    Dear Friends:
    Citroen (ES): 66C3-NFUR-UXYL-TACV
    Good Luck!
  15. #45
    Master!!!!!!!!!!.
    Thank you so much for your help, it?s working well!!!!!
