what type of channels are we talking about Sat/cable/IPTV
hi guys, just bought a zegemme h2s and all the channels are all over the place no order wot so ever, so was just wondering how to get the channels in order, this wont be the last post on this subject as iam only used to openbox , so any help would be useful.
cheers.....................c
A LITTLE THANX GOES A LONG WAY
WD40 (24th June, 2017)
hi m8, just the free view sat......................c
Dependant on Image use the ABM feature (Autobouquet maker) this will arrange all channels into order and in folders (FAVS)
hi, thanx for reply, how do i find out on what Image iam using? also where do I find ABM? bear with I'am new to this box ..................c
I would recommend flashing your box with martin035's image. It's already set up with ABM etc. & lots of instructions are provided.
http://www.digital-kaos.co.uk/forums...3-Backup-Image
It uses the OpenATV image.
The current image should be shown on boot up when you switch the box on from cold using the power switch on the back. Or you could try Menu > info panel > infos > image-version. Or menu > information > about.
chris31560 (24th June, 2017)
Yes martin035's image is great and always channels start from bbc.
