e46 330d p1640 eeprom fault.Help!
Results 1 to 9 of 9
    Nov 2009
    Default e46 330d p1640 eeprom fault.Help!
    I had my e46 330d remapped and ever since I keep getting p1640 05696 eeprom configuration fault code. can anyone help me fix this damn code.
    I have attached the original AND tuned file on here in case any of you genius's can take a look to see if the faults in the tuned file.
    i also read about trying to resync the DDE EWS through INPA
    Is this a good idea? I also have DIS SSS etc etc but not sure about programming so bear with me. I am able to flash to ecu though
    here are original and tuned files
    thank you in advance for reading/looking
    Jun 2013
    EU
    Upload files ton orum and attach them to message don't use external servers please.
  3. The Following User Says Thank You to morgano For This Useful Post:
    claire75 (22nd June, 2017)
    Nov 2009
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Try this one friend.
    Pass PM.
    100% ok file.
    must work.
    What did you use to write this?
    Chiptuning - Diesel / Petrol / Stage1,2,3 / HIGH Petrol Tuning
    DSG TUNING
    DPF / EGR / TVA / SAI / Lambda
    Crackle map ( Launch Control + No lift Shift + Antilag )
    File Service
    PCMFLASH / BFLASH / AMT BST / AMT MPPS / TGFLASH / BITBOX / EDCSUITEPRO - Genuine USER
  6. The Following User Says Thank You to maajkii For This Useful Post:
    claire75 (23rd June, 2017)
  7. #5
    Nov 2009
    mpps v13.02iirc. can you tell me what was wrong with tuned file? I also have galletto 1260 cable i can use
    thank you
  8. #6
    maajkii's Avatar
    Mar 2017
    Quote Originally Posted by claire75 View Post
    thank you
    I can't tell you
    Try my file and let me know if everything is ok.
    DSG TUNING
    File Service
  9. #7
    Dec 2019
    [COLOR=rgba(0, 0, 0, 0.54)]
    [/COLOR]
    [/COLOR]
    hello could you pass me the file of the switchboard of a bmw 330 d e 46 184cv
    [/COLOR]
    [/COLOR]
  10. #8
    Dec 2019
    hhello could you pass me the file of the swichboard of a bmw 330d e 46 184cv
  11. #9
    Jan 2021
    Did this map worked for you ? The fault dissapeared ?
