    Member irco's Avatar
    Oct 2014
    Default BOSCH VP44 PSG16 Fuel pump help
    Hi every body
    I need help for Bosh PSG16 pump
    If some one know the replacement parts for the component circled in red in the attached picture
    Apr 2012
    BG V.T.
    2 x mosfet eg irlr2905
  3. The Following User Says Thank You to stevebbb For This Useful Post:
    irco (23rd June, 2017)
    Oct 2014
    Quote Originally Posted by stevebbb View Post
    Thank you very for your reply
    It's sure that I can replace them with irlr2905?
    there is only 2 wires, the third go where
    EDIT:
    After some searches...
    Can some one confirm if it's the correct wiring. Many thanks
    Apr 2012
    BG V.T.
    Wrong
  6. The Following User Says Thank You to stevebbb For This Useful Post:
    irco (24th June, 2017)
    mapexo's Avatar
    Mar 2017
    Germany
    I have problem with transistor dead on the right... possible pinout for change ?
  8. #6
    Apr 2012
    BG V.T.
  9. The Following User Says Thank You to stevebbb For This Useful Post:
    mobiNik (15th November, 2021)
