Results 1 to 3 of 3
    Default 1998 Renault clio emergency code from vin
    Hello friends
    I need help with the emergency code, the key has no sticker, I tried to do immo off,But after a period when the vehicle is turned off, it no longer start, the only option in the meantime is to try to start through the emergency code and cut a wire 29 and see how it responds.
    vin :VF1B57J05W0012663
    CLIO 1.4CC- 1998
    THANKS
    coolsoda's Avatar
    Apr 2008
    Scotland
    Sometimes you can read key by pressing hard on circuit board,then you can make a new transponder on T5.
    or Just read 93C46 and make a new transponder
    Quote Originally Posted by coolsoda View Post
    Hello, my friend
    Thanks for the response, but if you notice that this is a fenix3 ecu with IR key
