Hello,
I have ML230 Gasoline W163 1998year and car wont start.
Engine ecu : VDO
412 229/021/006
MSE
022 545 57 32 [00]
1- read fault's in engine ecu was : 0C2 - Can Signal IR central. lock System faulty.
2- in AAM ecu no fault codes.
3 - take new chip PCF7935 and done with Avdi
4 - using Avdi read engine ECU eeprom 24C02 and done new.
5- read AAM ecu using MB -> AVDI -> Das2B function and Learn transponder and write "transponder learned ".
6- read again fault codes in engine ecu and AMM block's but no fault codes in any ecu.
7- Car same wont start :/
Without star diag imposible adaptation of engine ecu ore AMM?
Maybe some one can help me?
Thank you for help.
