Thread: ktag problem
    Feb 2013
    Lithuania
    Default ktag problem
    hello, today have big problem with ktag made in china.. opel vectra c denso ECU, i can read, but can`t write, and get error ''error ECU not identified - 0x100B'' anyone have ideas how to fix this problem ?
    Jun 2013
    EU
    Maybe need different wiring for writting? check help.
    Feb 2013
    Lithuania
    2 times i can write, but need 3 time write and can`t do that, with wiring 100proc OK..
    Jun 2013
    EU
    Then can't help further, sorry. In help files show different rainbow cable for read and write, also a jumper wire. Recheck all your connections, if worked two times don't know why it would not work a third one.
  5. The Following User Says Thank You to morgano For This Useful Post:
    smirnoff_rules (23rd June, 2017)
    Nov 2014
    Post ecu and diagram maybe someone can help
    If diagram is different
    Aug 2010
    Hi I have ktag made in china, with same problem whitch you had.
    Car is Opel Astra with Denso ECU, i can read, but can`t write, and get same error ''error ECU not identified - 0x100B''
    Did you find how to fix this problem ?
