connect a coil to the dash and but your key there the pins in dash are pin7 and pin8
i try use fvdi box [ vag v21 ] to read immo data of vw mk5 cluster 1k6 920 864 and i read Conf Data
but i cant read immo Data ... want to swap clocks half fis to full one.
Come up in screen
....cannot enter boot mode make sure you have ignition on with working key....
How can i connect key reader on bench to get acces to immo
ive done eeprom dump : - range 0x812 - 0x9BF in hex editor with FF FF so (immo is active) doesn't come on clocks
but still i cant read immo...
what i doing wrong ? ? ? or what im not doing right ? ?
I attach few pic of the bench
The for any advice's
ok, Thx i try get some spare coil ...
did is possible to brake security and read that immo without key ? ?
I just done immo reading in tiguan 2012 color cluster 5N0920882C on 24C64 and no key ... but doesn't work on OLD MK5 :/ 2007....
Works, use vag 18 or carprog.
English only in the forums
put dash in boot mode after mod your eeprom whith fvdi.....also check power on ignition coil and two transistor from power source of dash....
Panora (30th June, 2017)
Reading working form the car by OBD but not on bench.
gopelhu (20th January, 2018), raptureready (1st July, 2017)
