Results 1 to 7 of 7
    Sep 2015
    Default Good tool for cloning Delphi delco Hsfi 2.1-2.5 ?
    Hi guys,
    Im doing some experiement with Opel hybrid ECU's
    I want to know whats a good tool for cloning HSFI 2.1-2.5 Hybrid Ecu's from opel.
    Regards,
    Galletto 1260 is sufficient to read-write flash,use carprog to read pin and opcom to learn immo.Also one version of opcom read in this ecu pin...
    DK Veteran mariazo84's Avatar
    You can not describe them better 12
    Apr 2014
    hsfi 2.1 can be cloned with carprog. read eprom and write to donor ecu via obd. reads out pin and can reset also
    Sep 2015
    Quote Originally Posted by sjc1 View Post
    And what is a good tool for HSFI 2.5?
    Aug 2018
    East Pole
    Hsfi 2.5 works with carprog for eeprom dump. Tested. You have to read and write it at the delco hsfi 2.0 line, at k-line opel in carprog. For flash, you can use mpps, galletto, kess
    Sep 2016
    Hello friends, I have an HSFI-2.5 ECU from Corsa car and I need to clone data. Can this ECU's be cloned on bench ?
    Thank you
    If helped please "thanks + reputation"
