HI OK
in attachement you will fonde a virgin file for the ecu warit to the chip and reprograme the key
PIN D9 CF 7D E3 0E 9B
GOOD LUCK
HI THE PIN IS FROM THE UCH FILE IN THE 1 POST
USE THE PIN THAT YOU HAVE PROGRAMED THE KEY AND UCH SECCUFUL
HI YOU ARE CORRECT I HAVE SELECT CLIO2 NOT TRAFIC
The car still don't start. Immo light still on. The only one difference is that code of injectors are AAAAAA, but i still can't program them and VIN (with Clip). There is also no synchronization between ECU and UCH (in Clip: - synchronization - not done,- learned code - no,- car start - prohibited). What can we do now ?
HI
@ MR:KISZKA i give hime becuse the virgine fill is not autocoding
@ MR: DUDSON86 THE NEW ECU HASE THE SAME SW/HW AS THE OLD?
the key is synchronized with the uch (with pin code) ?
HI READ POST 6
GOOD LUCK
Hw same, sw i dont have idea. Tell me last thing: after virgin ecu, before start and without injectors coded , immo Light should be still on?
ecu virgin , after switch ignition on and wait the ecu learn the code
Ok so if immo light is still on - ecu is not learning properly. Maybe flash memory is bad ? I don't know what soft is inside. Maybe someone has dump for ecu and uch that i can write to them both? (codes in ecu and uch will be same)
witch ecu do you have ?
l have pdf document if you want but in french on this uch
l can't upkoad files on the forum , l don't know why
