Page 4 of 4 FirstFirst 1234
Results 46 to 59 of 59
  1. #46
    CHIKO's Avatar
    Jun 2014
    HI FOR THAT YOU WILL NEED TO GO TO THE DEALER GET YOUR CAR DOCEMENT AND ASK HIM INFORMATION OF YOUR ECU
    GOOD LUCK
  2. #47
    May 2017
    Hello To Everybody
    I take off from TATA Xeron ECU Delphi with FGTech Galleto v54
    Runing on MPC555LF8MZP40
    on Infineon
    Please i need the immo off for this
  3. #48
    Mar 2015
    Quote Originally Posted by CHIKO View Post
    GOOD LUCK
    Ok i should have ECU or SW from Mascott with ZD3A600 engine - 85kW. HW is ok but the ecu can also be from Renault Master so i need full bdm for this ecu. Maybe someone has sth like this ? I see only one corrupted file on DK. Google searching ...
  4. #49
    kiszka's Avatar
  5. The Following User Says Thank You to kiszka For This Useful Post:
    dudson86 (1st July, 2017)
  6. #50
    Mar 2015
    I've probably found The reason. I cant communicate with ecu via can. Can someone confirm that to synchronization between ecu and uch, and also to code injectors can is necessary?
  7. #51
    kiszka's Avatar
  8. #52
    Mar 2015
    Finally problem solved. Can module in UCH was broken. Unfortunatelly Clip didnt report any errors on UCH module.
  9. #53
    CHIKO's Avatar
    Jun 2014
    HI CAN YOU TELL MI WHAT FILE YOU HAVE USE TO VIRGIN THE ECU
  10. #54
    Mar 2015
    i used file from my first post but i can check your files if you want
  11. #55
    kiszka's Avatar
    Reality of life :
    1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
    2:Envy is the confession of inferiority
    3:Everyone lies
    How much trash you leave behind so much trash someone will have to read or maybe you yourself
    If you like reading garbage, don't slow down, just speed it up
  12. The Following User Says Thank You to kiszka For This Useful Post:
    CHIKO (10th July, 2017)
  13. #56
    CHIKO's Avatar
    Jun 2014
    HI THANKS MR:KISZKA i ask to get all image of the problem for this unit i have a sulition
    GOOD LUCK
  14. #57
    kiszka's Avatar
    Reality of life :
    3:Everyone lies
  15. #58
    Jan 2014
    HELLO,
    can you help me with working pair eeprom 95160 from ecu + 93c66 from uch
    i have Mascott 3.0 with ecu 0281013806 i virgin it but Immo light still on
    thank you
  16. #59
    Jan 2014
    solved.
    thanks to dudson86
    br
