Here is your dump changed to code 1234 if ok
car_soft_gorj (27th June, 2017), Decode Ghost (28th June, 2017), ilen (27th June, 2017), tvzmaj (13th April, 2018)
i change 1234 0000 but not work eep is asigment with flash not work to change pin only org pin code. thanks for help !
anyone ? ? ? ?
try origine code 0973 ..............
attilaa0 (18th November, 2018), car_soft_gorj (4th July, 2017), Decode Ghost (16th April, 2018), irfa (4th July, 2017), masterskay62 (4th July, 2017), Mezz_cro (12th October, 2017), nigrou (4th July, 2017), smoggy (4th July, 2017), sonices (5th July, 2017), yahia1908 (16th April, 2018)
mohamad1401 (4th July, 2017)
Hello
someone help with code?
Decode Ghost (16th April, 2018), ilen (16th October, 2017)
RCD215 SK 1ST035156C
Made by TechniSat sw0051 hw h03
SKZAZ1N
Need code and resset SAFE 2
Code entered without eeprom. Code is ok.
With eeprom displayed Code and Safe 2
Need resset eeprom.
1skodaup.bin = Counter 0. This is dump before two wrong codes were entered.
after two wrong codes, displays Code 2 and then Safe
We got the correct code: 1864
eeprom removed and entered 1864. Radio is work without 24c16. eeprom(with 1skodaup.bin) is entered with socket while the radio works. After 30min radio going to off. Turn on is displayed Code2 and then Safe...
Attached is the dump after 30min.There are changes in it, but I no idea. I believe that reading the processor will solve the problem, but no tools...
Maybe someone has a solution/proposition/idea from eeprom?
The whole venture is from colleague from the forum, I just assist
i think dump changed Not original !
your SN in dump : SKZAZ1N0286877
Please check the serial number on the radio sticker ....
Decode Ghost (16th April, 2018), tvzmaj (15th April, 2018)
