2016 infinity Q50 98820-4HL0A 95128
Results 1 to 7 of 7
    Default 2016 infinity Q50 98820-4HL0A 95128
    I used file from another post now I have no communication with the module.
    Or if someone can clear it for me thanks. When I compare file they dont look simliar. I think I might be reading under wrong chip with vvdi prog.
    Is it chip 95128 because I see H128 54042 written on it?
    does someone have pictures to confirm the orientation of the chip I tried looking through tacho database and pictures were not clear enough.
    2016 infinity q50
    srs 98820-4hl0a
    95128
    FxShaw's Avatar
    Nov 2013
    Outta This World
    H128 is correct...send pic of the board
    weird this file structure is a little different from the ones i did before.
    anyways try this
    🔥Wacka Wacka 🔥
  3. The Following User Says Thank You to FxShaw For This Useful Post:
    mojomojo (27th June, 2017)
    I think my vvdi prog is not reading this chip correctly is there an alternative chip selection I could make like what's done with 95640?
    fxshaw doesnt seem the same as this one thats what makes me believe the vvdi prog is the problem ...i read it off board
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Quote Originally Posted by mojomojo View Post
    Try the file and see I guess..I hope u verify after reading it. only read as 95128
    🔥Wacka Wacka 🔥
  6. The Following User Says Thank You to FxShaw For This Useful Post:
    mojomojo (30th June, 2017)
    Aug 2016
    none
    I THING IS YOU MODULE BAD
    THE OTHER SIDE THE BOARD GET HOT TO MUCH
    WHEN YO REMOVE THE CHIP
    YOU HAVE WRONG FILE YOU SCANNER
    SHOW YOU ONE CODE
    BEFORE I HAVE THE SAME PROBLE SAME MODULE
    I MADE THE SECOND VERY SLOW NO PROBLEM
  8. #6
    Quote Originally Posted by FxShaw View Post
    Hello folks can someone clear this read...
    Also is it possible for me to fit a module for a 2015 which has a different part number(98820-4hb0a)? And do these modules need programming if the original one was not put back?
    Thanks everyone for their time and Help!!!!!
  9. #7
    FxShaw's Avatar
    Nov 2013
    Outta This World
    Done and yea can get away with diff part # on some of these.
    🔥Wacka Wacka 🔥
  10. The Following User Says Thank You to FxShaw For This Useful Post:
    mojomojo (29th September, 2017)
