Results 1 to 3 of 3
    Nov 2015
    Detroit
    Default bmw cas3+ problem
    ok so this is the problem am having i went to do a 2008 3 series i pulled the cas3 out i read it with r270 clone i set it to 0 put it back to the car with the dash adjusted everything worked fine, next day i get a call from the customer that the car does not want to start nothing works dosent even get the key, i get there i write original back and car works, now that was saturday today guy calls me again same problem. could it be that when i read the very first time it was corrupted when i read so my original is bad? can anyone help me check if my eeprom or flash is bad and fix it please thanks
    elier-original-0L15Y(512).rar
    nickolasd's Avatar
    Nov 2015
    bin looks ok, vin F009139 milage 230717km
    prob cas problem.
    friend of mine also had same problem once!
    check for bridges soldering or check your flash.
