Results 1 to 4 of 4
    Oct 2013
    Sudan
    Default P1118 & P0571 needs to disable from VW Bora
    Hello,,,
    i have two codes
    P1118 Volkswagen HO2S Sensor Heater Circuit Open Bank 1 Sensor .
    P0571 Volkswagen Brake Switch 'A' Circuit
    can you pls disable it for me
    Apsik's Avatar
    Mar 2015
    just behind you
    Post ori file
    If you find my post helpful please hit Thanks button.
    You can also hit Reputation button if you are kind enough.
    Apsik's Avatar
    Mar 2015
    just behind you
    Rear O2 sensor & KAT diag completely OFF,
    06A906032GG (VW Bora (Rear O2 OFF) - 363048).zip
    I can't help you with P0571, my suggestion is to check wiring.
  4. The Following User Says Thank You to Apsik For This Useful Post:
    yem22 (28th June, 2017)
    Oct 2013
    Sudan
    Thanks A lot Apsik ...worked perfect !!
