Results 1 to 11 of 11
    Sep 2016
    Default service Km show 0 and can not be set after milage correction in bmw e90
    Hello guys. I just bought digi master 3 and have done bmw e90 milage correction ( cas 2 ) . now everything is ok. but i have problem with my service kilometer and dates.
    since all of them show somthing like ----- KM or --:-- I started reset them manually and with my diagnotice toll. But I was just enable to set the date and time. When i try to set to set them manual it can not save the number. please help me what should i do to this crazy head lady E90 ?
    immokill's Avatar
    Jun 2009
    UNIVERSE
    drive car few miles and then turn off ign lock car unkock and put ign on
    Here to HELP!
    Sep 2016
    Quote Originally Posted by immokill View Post
    im going to try it. I already drobe such 7 mile with it and. few times on and off, and also lock and unlock. does it load it it previews service km*?
    brend's Avatar
    Oct 2015
    Same where
    ........clear.............
  5. The Following User Says Thank You to brend For This Useful Post:
    lostmoons (28th June, 2017)
    Sep 2016
    Quote Originally Posted by brend View Post
    Try disconect batery 10 min.And connect back and reset CBC use tool like bmw ista,launch,inpa,......... .
    I tryed ... also with lunch, alctually all number inside cbc are messed up. when i try to reset it, it sayes
    it can not be baried out.
    maybe because of their availebility persentage. most of them shown 255 % in my computer .
    and when i wan to correct cbc value , in the most cases it says, due date can only bought forward. I tried from 2000 to 2020 also in most of them.
    situation is going to tricky for me please help if you have any other suggestion.
    something else, My service due date and km in dashboard are all shown with line like (--,---)
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    Make CAS again to 0km
  8. The Following 3 Users Say Thank You to lupu_sandu For This Useful Post:
    immokill (5th July, 2017), lostmoons (28th June, 2017), sagie1zn (29th June, 2017)
  9. #7
    diagtech2000's Avatar
    Jul 2013
    North of England
    U got tamper dot on?
    Please hit thanks if this helped you!
  10. The Following User Says Thank You to diagtech2000 For This Useful Post:
  11. #8
    Sep 2016
    Quote Originally Posted by diagtech2000 View Post
    can you explain a little more about it?
  12. #9
    In EEP
    Quote Originally Posted by lostmoons View Post
    make wath write lupu sandu on cas only 0km no new mileage write back eep on das and service work ok
  13. The Following 2 Users Say Thank You to vasa For This Useful Post:
  14. #10
    Sep 2016
    ok. tomorrow i will try to it. I hope it works out.
  15. #11
    Sep 2016
    hello my friends... You are so ~~~~ing awesome guys. my problem solved by changing cas KM to 0 . and digitech2000 was true. it went to tamp dot mode.
    I believe because of diferent in service details and number, it went to tamp dot . ( since I changed vin and km and write like each other. )
    I am so happy to be here.
    please guys, I am electrical-mechanical expert, if you have any question dont hesitate. and ask me in privet ... I will be so happy to answer
