Results 1 to 5 of 5
    Default 2006 Range Rover - parking aid module issues
    Hi guys,
    I have a 2006 Range Rover HSE with an issue with the PDC or parking aid module.
    It appears as though module is not sending signal to front or rear sensors. DTC's from module at B1B57 and B1b58 which are for Front and Rear Sensors power circuit/
    If anyone has some idea on how to resolve, this would be greatly appreciated.
    Yes,change parking module. It's at fault. Done many.
    hello
    i have same broplem ar you sloved it
    Meat-Head's Avatar
    implys two duff sensors or broken wire, one goes down kills the lot
    often aftermarket suppliers can supply
    Aug 2011
    uk
    Like meat head said, if one sensor on the front is shorting it shuts the lot down, if you check power direct at the sensors then you can work out which one it is as it shuts down the 12v feed so unplug one at a time until you get the feed back, modules in rear left behind panel towards window
