Audi Q7 4.2 FSI MED9.1.1
Results 1 to 12 of 12
    waldi1979's Avatar
    Dec 2010
    Default Audi Q7 4.2 FSI MED9.1.1
    I have Audi Q7 4.2 FSI 2006. ECU MED9.1.1
    My original ECU is broken (water is inside). I read ori ECU by BDM. Flash and Mpc is OK, but EEP - only 00.
    I read 95160 by programmer, but when I write flsh, mpc and eep, or only eep (read by programmer) to the second ECU I have ecu error and the car doesn't start..
    I think my ori EEP is broken (I compare it with other ones).
    I need Immo off NEW ECU or transfer immo data from ORI -> NEW EEP.
    Tnx.
  2. The Following User Says Thank You to waldi1979 For This Useful Post:
    Luis Jaued (14th October, 2019)
  3. #2
    Jun 2013
    EU
    Quote Originally Posted by waldi1979 View Post
    Tnx.
    Ok, try this one. Flash and MPC from the original ecu you could read fine, and this eep composed form both.
    good luck.
  4. The Following User Says Thank You to morgano For This Useful Post:
    waldi1979 (29th June, 2017)
  5. #3
    Jun 2013
    EU
    Hello @waldi1979
    Have you tried the eeprom? Did it solve problem?
    Regards,
  6. #4
    Mar 2017
    hi try these two files the eprom and flash and replay
    the immo is off of your new files
  7. The Following User Says Thank You to ZAHEER For This Useful Post:
    waldi1979 (30th June, 2017)
  8. #5
    Mar 2017
    by the way only eprom immo off or write will not work need the flash to be immo off as well
  9. #6
    waldi1979's Avatar
    Dec 2010
    Quote Originally Posted by morgano View Post
    Hello @waldi1979
    Regards,
    SAFE on display....
  10. #7
    waldi1979's Avatar
    Dec 2010
    Quote Originally Posted by ZAHEER View Post
    I will try tomorrow.
    I write ori MPC, FLSH and "repaired" EEP (old+new eep).
    No SAFE, no errors..... no spark, no fuel injection.....
  11. #8
    Mar 2017
    try the one i give you dear and replay
    you need the file which i give you eprom and flash to write and replay me then i can help ahead if some problem occur
    and before to write the eprom and flash i gave you try to read the eprom and flash again to keep the new ecu data safe with you once more
  12. #9
    waldi1979's Avatar
    Dec 2010
    SAFE on display and 1 spark after connecting ECU.
  13. #10
    Mar 2017
    make new transponder and learn to the car and start the car
    first learn the original key to the car if not work make new transponder
  14. #11
    waldi1979's Avatar
    Dec 2010
    Probably my "new" ECU or the car is damaged. Now I have only thottle error . I managed to start the car twice but after turning the engine off it wasn't possible to start it again.
    I order anothet throttle...
  15. #12
    eprst's Avatar
    Jul 2011
    Russia
    Hello, What ended your story? I have a very similar case
    THANKS + REP if I help you
