any help please...............
hello guys ,
i have mini cooper with fault code
2868 - valvetronic servomtor, sluggish movement
2FD9 - INTERFACE EWS IMMOBILIZER -DME
2869 - valvetronic servermotor,electric
my main problem is 2FD9 I did DME-CAS synchronice yet get the same fault code 2FD9
ecu
DME7600008
BOSCH
0261201743
CAS
61.35-9147196-01
2073421707
00.00.00 2.1.6 3.3.0
Please have load ecu and cas file here
i read ecu with ktag and cas with r270
please check file if is ok
car cranks but not run
thanks.
Hello
In your files sync is okay.
view the status of the EWS. Allowed or denied.
I think you need to fix errors Valvetronic
philipcoin (1st July, 2017)
Check wiring first
try with istad syn cas-ews in service plan
Phillip Did you fix your problem, i have a 2010 Mini cooper with the same problem!!!
thanks in advance!
A simple thanks would do, If it didn't work at least I tried.
solved....................
