klakier (26th November, 2017)
Hello everyone,
Just finished working on this Durango today. Tried Launch and Snap-On to erase crash with no success.
EEPROM chip does not have anything on it so I read it as 95640.
Can someone Please, pLease, plEase help?? I will report results right away. Thank you!
Im not sure, but try read again like 95128 and post here file, ok ?
Best regards.
Dragon
repairmymodule (29th June, 2017), slavax (5th July, 2017)
Look closer at chip, as Dragon says, should be 95128 or 95256
Had to remove the chip and looked under the microscope It is 95128. Thank you guys!! Here is the file:
Try and report, not tested, it is a fresh ...
Best regards.
Dragon
Crash data error went away, however. I am getting B2207 "Occupant Restraint Controller Internal 1" Error.
Try to 00 line 29E0 through line 3200
Try a little different clear ...
Best regards.
Dragon
Ok, dragon, after loading your new file I have 2 errors in total: Deployment Data Record and Occupant Restraint Controller Error.
After using your first file I had only Occupant Restraint Error but Crash Data was not present.
I might be wrong nut this can only mean that in your first file you cleared the crash data but deleted some extra stuff needed for the module to function normally.
Thank you!
I'm just curious, I know when you started you just had crash data code, but now If you load your original file do you just have the deployment data full, crash code?
Your original file looks not very good.
But, though, try this.
2017 DODGE DURANGO 95128_p1.rar
Yes. When I load my original file I get the Crash Data message. I also disconnected two air bags to test the correctness of the original file/module. It shows the errors correctly after disconnecting air bags and I can clear them when I connect them back. Thanks!!!
dragon100 (5th July, 2017)
HI,
I have a problem with clear srs unit bosch 0285 0131. Below attached crash file. Thanks for help.
Best Regards
GG: 7541425
I'm not Sharing Passwords!
If my post was helpful, press "THANKS" button!!!!
adamwajda (14th September, 2019)
