Results 1 to 2 of 2
    Jun 2017
    Default WRX 2015 Dash Checksum algorithm.
    Good day to all!
    I recently installed a dashboard from WRX 2015 in my forester SJ XT, but some functions stopped working.
    It is required to reconfigure the dashboard.
    I've been trying to figure out a dump from WRX 2015-2016 for several months.
    Some technical information:
    Dashboard manufacturer: NS;
    EPROM: 93C76
    Processor: NEC V850
    What is achieved at this moment:
    ? According to my assumptions, all basic parameters of the Dashboard are stored in the first 3 lines of 10 bytes each.
    ? Each line with parameters consists of 10 bytes. The first 8 bytes are parameters, the remaining 2 bytes is the checksum.
    ? A checksum is required to verify the integrity of the data in the line with the parameters.
    ? The checksum in calculations uses NOT, since if the entire line is filled in 00, the control panel starts with the checksum FF FF, and vice versa.
    ? The test software-hardware complex has been assembled for the firmware and dump test of the instrument panel.
    What i managed to find out:
    By means of the experimental checksums, the following options were found out:
    B1-00-00-00-00-00-00-00; CRC = 4E-00
    B1-4E-00-00-00-00-00-00; CRC = 00-00
    B1-27-27-00-00-00-00-00; CRC = 0E-00
    B1-27-13-14-00-00-00-00; CRC = 2E-00
    I ask for help. An algorithm is needed to calculate the checksum.
    I believe that in this community I can be helped.
    If you need sponsored for the algorithm please PM me.
    Best regards Roman.
    Feb 2013
    this is an old post but just wondering if there was any success with this one?
    i've just tested a 2017 Levorg cluster in a 2013 XT.
    everything works except Eyesight is flagging a fault and also the S#/S/I mode is in fault mode.
    I need to plug in SSM3&4 to view faults and see if any adjustments can be made, and also get a dump from the eeprom
