Results 1 to 15 of 18
Thread: Zgemma problem
    Nov 2008
    Default Zgemma problem
    Right I just got a zgemma h2h put vix on it , and getting low signal rates on all Channels , nothing is clearing , and keep getting service not found , sid not found in pat , anyone got any ideas , net Id is correct and am at a loss now
    Many thanks
    plasterer's Avatar
    Jun 2008
    Mersyside
    Low signal levels is OK.
    29 percent mine runs OK on.
    Recheck net ids
    Select vm from providers and run auto bow k
    Let's know results. ..... paul
    PAUL
    Nov 2008
    Have done auto scan and get 397 channels , on my Id 41050 which apparently is correct even though area name is wrong , when I do manual scan , I only get 3 channels , :-/
    plasterer's Avatar
    Jun 2008
    Mersyside
    wot area are yu in.
    What net id are you useing
    Are you getting Free to air channels
    .............Paul
    PAUL
    Nov 2008
    Now getting a few premium channels clearing , others say something about Sid not found in pat , area code I'm using is 41050 , but picked up a genuine box and it's showing net id as 41051 , but that's no where near my house , am going to try it later when get home
    Nov 2008
    Would if code was wrong , only give me a few premium channels and create that error on others ?
    DK Veteran lincsat's Avatar
    Jun 2008
    You have put the correct NetID in the ABM and not just in the tuner config? If a subscribed box works with a certain area code, then use that.
    P&D's Avatar
    If you give us clue what area you are then we can give you the correct net ID
    or is this a guessing game ?
    Needed to pick up channels.....correct net id & correct symbol rate
    we can only guess at these without help
    Example Manchester...............
    Manchester 1 NTL ex C&W 41040 6.887
    Manchester 2 NTL ex C&W 41060 6.952
    2 different net ids & 2 different symbol rates but the same place
    Nov 2008
    Yep problem I have , I live in Shepherd's Bush , which is 41050 , but when I use that id I only get a few channels clearing , i.e. Sky sports 5 , but ss 1-4 show as no pat In sid , and yes but the Id into Abm and tuner , it's very strange , apparently you either get premium channels or you don't , it's shouldn't decide to just give you a few , like I don't have normal channels 1-4 but have channel 5 :-/ , thinking maybe cos virmin split off the neighbours feed , i( as my cable couldn't be traced ) it's causing some kind of conflict , what do you think ? But they supposed to be coming on Wednesday to pull me a new cable to my house , maybe that will solve the problem , but not holding out much hope
    Nov 2008
    Sheperds Bush NTL 41050 666.750 6.887 , am I supposed to do anything with the 666.750 6.887 ??
    P&D's Avatar
    Go in to your tuner settings net id 41050
    provider to scan VM UK 6887
    then do a manual scan you should get the channels
    I think you can also set this up in ABM as well..in the same way
    Nov 2008
    I don't see them numbers , I got options pure , bruteforce , no numbers visible , I scanned on pure :-/
  13. #13
    Nov 2008
    On my symbol rate , on tuning info it says symbol rate6952 -auto , maybe there lies my problem
  14. #14
    Nov 2008
    Somehow managed to switch rate , had to do manual scan and now all working , got lots of duplicates , can I run bouquets to clean it up
  15. #15
    P&D's Avatar
    Yeah mate I think so......I don't use ABM mate
