zegemma h2s.
Results 1 to 5 of 5
Thread: zegemma h2s.
    DK Veteran chris31560's Avatar
    wigan
    Default zegemma h2s.
    hi guys, does anyone know how to swap the channels round on a zeggema h2s, its just that all my fta's are ok apart from itv it shows utv (ERROR TUNE FAILED), any help would be great.
    chhers.....................c
    A LITTLE THANX GOES A LONG WAY
    digicon's Avatar
    Are you using the ABM to configure your Bouquets if so have you tried updating as ABM gets a regular update every few days, If not you can manually sort via the remote control
    wigan
    hi digicon, when I go to use ABM it scans for about 30 sec and then says AUTOBOUQETSMAKER timeout for tuner lock, and nothing changes, do you know wot is wrong.
    cheers....................c
    digicon's Avatar
    i take it you have you Twin satellite version , if so check the connections on the back as the Tuner lock timeout means its not receiving a satellite signal
  5. The Following User Says Thank You to digicon For This Useful Post:
    joe516 (2nd July, 2017)
    wigan
    yes I do have the twin tuner and I have checked the connection on the back nice and tight...................c
