Can i just say do we really need to keep quoting the 'Forum Rules' everytime, i think we all know how to receive Paid TV channels via an Illegal 'Sub' is a no go area whether that be Satellite,Cable or even IPTV
Footy season is over a month away and I'm stuck on what to do with regards on how to watch sly sports as well as movies. There is an app called iptv player but the the audio most of the time is behind which is annoying and the movies aren't really that good but there's a couple of decent apps within it. Is there another app on which you can directly view the channel such as sly sports 1 just like a MAG? I've done some research on MAG boxes and these are pretty solid for viewing iptv, however subs can cost quite a bit and is it worth paying 67 quid for a MAG254 and whatever on top for a sub or try to get IPTV on solo2 and watch it via that? I'm stuck and need help guys
Okay forget I mentioned the "sub".........any help on the actual issue?
You can quite easily use your Solo2 for IPTV viewing, All i can say is that some of the you know what like to keep there sources 'Hidden' and so will only deal with MAG and Android type receivers other son the other hand will allow you to use your Enigma2 receiver quite happily either using a Telnet/Putty script input or via the Xstream plugin.
Thats about all i can say, do a google search and all will be revealed
Can't seem to find the Xstream add on in kodi, I've checked in add ons and have searched but nothing as yet. I'm probably looking in the wrong place or what ever but if you can point me in the right direction then fine. It's late so I'll check again later on.
My mistake its the XCplugin do a google search it does not work through Kodi, You also need to do a search to find something 'Nudge' to work with it
Right thanks for that, I'll try to figure it out.
You can use the XC-Plugin or view the channels in a userbouquet. If using the bouquet, you can try changing stream type from 4047 to 1 or the other way - only FTA channels of course
super jumbe (13th July, 2017)
