Results 1 to 11 of 11
    EU Romania
    Default Need content data from unit Porsche Cayenne PCM 3.1 HDD 40Gb IDE ?
    Hi all,
    Can some one help me with content data from HDD 40Gb IDE from navigation Porsche Cayenne PCM 3.1 ?
    vanos batam's Avatar
    Batam-Indonesia
    hello
    same problem...
    EU Romania
    If you find some iformation how to fix this problem inform me. For the moment I don't have the unit.
  4. The Following User Says Thank You to Seby_TM For This Useful Post:
    vanos batam (5th September, 2017)
    Batam-Indonesia
    MY pcm3.1 Without HDD
    https://www.youtube.com/watch?v=Bku4Jc9aMMU
    this sometimes trun ON then OFF
  6. The Following 3 Users Say Thank You to vanos batam For This Useful Post:
    Pali33 (5th July, 2018), PremierD (5th September, 2017), wiseman (2nd March, 2020)
    I need the same because my HDD is broken !
    Can someone help me please ?
  8. #6
    Oct 2010
    EU
    My Porsche PCM3 have a problem. Every 30 seconds goes OFF and ON (reset every 30 sec). Is it HDD problem?
    Is there any solution for this problem?
    Many thanks in advance!
  9. #7
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Nope.
    Only navi wont work when HDD is broken.
  10. #8
    Oct 2010
    EU
    and do you know the reason of my problem? or any solution?
    EDIT: you are not right.I have now remove the HDD and now no reset every 30 seconds. All work permanent, only navigation not.
    Now i will try to repair the HDD data
  11. #9
    Oct 2010
    EU
    which HDD clone tool can clone (or make back up) of this HDD?
  12. #10
    Jun 2019
    I know this thread is pretty much dead.. but Pali33, did you finally make it work with or without the HDD ? My PCM3.1 is rebooting every 2 min. the HDD status is invalid and the NAV wont work anymore. I don't care about navigation anyway but I wonder if I can have the reboot problem solved by removing the HDD.
  13. #11
    Oct 2010
    EU
    yes, the PCM3.1 have working good and permanent without HDD (in may case). Just the Navigation works not.
    I have tried to repair the HDD with "HDD regenerator", but no succes. So i have remove the HDD permanently and it have works.
    good luck
