Hi, emulator Ems 3132.
http://www.autotronika.pl/pl/katalog...ult-z-can.html
Hi dear friends. I have a Nissan platina 2006 with ems3132 ecu . the same of Renault clio and i am dedperate about remove immo. I tried many dumps, lots of options, i buy a couple of software trying to solve my problem but led In dash still blinking, i assume my ECU isnt can because have pin 58 green wire on it, i cut the wire In first try and still cut but All times les blink on dash. With some dumps led blinks and fuel pump works for a second, i try to start but no spark and no inyector pulse, In second try the pump keept off. With some dumps even the pump do not work, All times led blink on the dash. I really hate that led my friends. My ECU still seems good, but i remove and solder the 29f200 more than 30 times and im scare to do that more times. I have All the stuff to read andvwrite sop44 but after 2 months of hard work with no results im ready to start a barbecue with the car, just for my mental health.
Please if you have some clue i really apreciate. Im 24/7 think In that car because i really needed.
Thanks for advance.
Enviado desde mi 5015A mediante Tapatalk
Damn emulators are not aviable In my country
send ori file
Original. Thsnks bronissan platina immo ON.rar
If this like renault ..
With original dump fuel pump must work for few seconds after ignition on..
If not you must check relays and wiring .
If immo light flashes then fault with key , key reader or UCH..
If immo light solid then fault between uch and ecu ..(wiring .relays )
What fault codes you have m8
Coded line circuit?
I buy the car with led blinking. Key are original and chip still good. Last owner says he go to childrens school and he back try to start but led blinking and never start again. I change ckp and try lots of dumps without result. With some dumps fuel pump turns on, with some other not. Led blink quickly with All dumps
Please put diagnostics on the vehicle and give us faultcodes ....................................
I havent Renault clip for this car, i have lexia, elm327, op-com and others like Toyota tis but no One can read the ECU, elm327 connect with car but never show errors or parameters. Is any way to read dtcs without expensive hardware
