Results 1 to 8 of 8
    Member hd2391003's Avatar
    Apr 2015
    Default Need dump Mini R56 Footwell Module 6135 3453743 - 01
    Hello all. I need good dump for FRM2 Mini R56 2008
    My org dump error high beam headlight.
    Frm2 module info : R56 HIGH EKS PL3 FRM II
    S : 61048 / HW 09
    Thanks in advance !
    FRM2_9S12XDT256_0L15Y_30032017.rar
    Jun 2012
    Hi, can you still read DFlash, if so post the DFlash .
    Alsoi have close numbers to that one but not that exact number, post the last 7 of the VIN i iwll check if any are suitable.
    Nogger1
  3. The Following User Says Thank You to nogger1 For This Useful Post:
    hd2391003 (14th July, 2017)
    Apr 2015
    My friend. I write PFlash, FRM is dead , nocomunication with FRM.
    Mini R55 , Vin TP88521
    Please help me write dump to PFlash.
    Thanks in advance!
    Jun 2012
    You do NOT need to touch PFlash, you only need to read and write DFlash and EEP. IF you have Xprog or similiar programmer see if you can access the DFlash. Initially it will be set to zero as EEP will have claimed all the memory so you need to set DFlash to maximum (32768 ) and EEP to zero . IM me if you don not understand.
    Nogger1
    Sep 2019
    Thanks for posting this
    Dec 2019
    can anyone help to get FRM dump for R56 AHL EKS FRM 6135-3456586. thank you
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    Quote Originally Posted by goldenmotor View Post
    Check here
    https://www.digital-kaos.co.uk/forum...-FRM-Dump-need
    May 2017
    Iam searching exactly same dumps.
    S : 61048 / HW 09
    6135 3453743 - 01
    VVDI Read of mine FRM attached, maybe some can repair or got the files i searching for.
