Hi, can you still read DFlash, if so post the DFlash .
Alsoi have close numbers to that one but not that exact number, post the last 7 of the VIN i iwll check if any are suitable.
Nogger1
Hello all. I need good dump for FRM2 Mini R56 2008
My org dump error high beam headlight.
Frm2 module info : R56 HIGH EKS PL3 FRM II
S : 61048 / HW 09
Thanks in advance !
FRM2_9S12XDT256_0L15Y_30032017.rar
Nogger1
hd2391003 (14th July, 2017)
My friend. I write PFlash, FRM is dead , nocomunication with FRM.
Mini R55 , Vin TP88521
Please help me write dump to PFlash.
Thanks in advance!
You do NOT need to touch PFlash, you only need to read and write DFlash and EEP. IF you have Xprog or similiar programmer see if you can access the DFlash. Initially it will be set to zero as EEP will have claimed all the memory so you need to set DFlash to maximum (32768 ) and EEP to zero . IM me if you don not understand.
Nogger1
Thanks for posting this
can anyone help to get FRM dump for R56 AHL EKS FRM 6135-3456586. thank you
Iam searching exactly same dumps.
S : 61048 / HW 09
6135 3453743 - 01
VVDI Read of mine FRM attached, maybe some can repair or got the files i searching for.
