Spr?buj tego dpf off peugeot.
Hello friends,
im asking you for your help today as im stuck with a peugeot in my garage for weeks now.
its a peugeot 206 cc 1.6 hdi FAP with Bosch EDC16C34 part number 0281011628
i need a working DPF Off solution, because i emptied the DPF and im still struggling with P1446 and P1445 error code which points to additive system.
its a pain in the ass guys and im stuck with my knowledge. i dont know any further, could any of you guys please help me
neither ECUSAFE nor Volta solution worked. please help me and give me winols solution.
i would highly appreciate your help. if you demand money, no problem.
thanks for your help in advance
abdulsattar (10th July, 2017), Imou01 (4th August, 2017)
HI HERE YOU ARE OFF DTC AND DPF OFF
TRY AND REPORT
thank you so much my friends i will test and report
hi friends,
i tested today and neither of the two solutions posted is working.
i think problem is my mpps clone. it seems to me that it isnt writing the entire file into ecu, is there something like a security mechanism that prevents writing by obd?
is any of the posted solutions tested and works 100 percent as im giving it to a chiptuner tomorrow for flashing?
is kess working good with edc16 ecus?
thanks in advance
file dpf dtc egr off cks repaired
abdulsattar (11th July, 2017)
Kess clone works very good
abdulsattar (26th July, 2017)
Thanks a lot guys, i bricked my ecu because mpps clone didnt read orig fileproperly. when trying to write back the ecu was bricked. therefore none of the tested solutions was working for me. i ended up biying a complete new ecu have it recoded
be careful with mpps clone and edc1c34 on Peugeot and citroen cars, high risk of brick
thanks a lot for your help guys, i really appreciate it
