here my friend 1 key
write dump in ecu eeprom and start the car
I have a Toyota Yaris 1.4 D4D year 2001.
ECU is Bosch 0281010563, Toyota 89661-52200
Inside ECU is eeprom 95P08. File is attached.
Car has no Keys. I have a Key from another Yaris and I would like to add this Key info into this ECU.
Can anyone help me ?
I read the Key with Zedbull and it says:
DATA: 7E1C03B36000000000D8117E0000
TYPE: 4C TEXAS WR
Can someone modify my dump to add this key ?
Thanks for your help
aqua_life (12th July, 2017)
I am aqua_life from the above post. But now I canīt login with my account.
I tried your file but I still canīt start the car.
I can do diagnostic to Engine, Airbag, ABS. But I cant make diagnostic with Immobiliser box. I think this car has immo box. Shouldnīt I also modify immo box ?
Engine ECU has 1 error code: B2799 Engine Immobilizer Malfunction.
Can anyone help me with this problem ?
the immo data stored in the bosch ecu. Try to write back your backup.
danhash (8th August, 2017)
Ok. Thanks.
I have original eeprom dump of ECU, but with that dump car wonīt start.
Costumer lost all keys. So, I got an used key with data:
TYPE: 4C TEXAS WR
Then I asked for someone here in forum to add key info to dump. But car still donīt start.
What should I do ?
Attached you have original dump and modified dump with the Key I currently have.
sorry but with my all tools i can make working transponders but i'm not able to add used keys to the dump
If there is no other way switch off the immo. Look around the DK "immo" forum
NO IMMO OFF<! NEED PROGRAM KEY TO START CAR
I'm trying to make a spare ECU (EDC15C9) work in my 2005 Yaris Verso D4-D (NLP22) to have a backup ECU when things go wrong.
The first thing I did was to blow the EEPROM using a miswired programmer - so I hope to get at least SOME working image...
