Results 1 to 15 of 15
    Apr 2013
    Default Peugeot Boxer 2.2 Visteon EGR
    Hi.
    Can somebody make EGR off to this file?
    ECU : Visteon DCU102
    HW : 9661256980
    SW : 9666701580 6C1U-12A650-ES
    Thank you.
  2. The Following User Says Thank You to 2xded For This Useful Post:
    bugarcek (12th July, 2018)
  3. #2
    There is egr off
  4. The Following User Says Thank You to nikka For This Useful Post:
    2xded (13th July, 2017)
  5. #3
    Apr 2013
    nikka, EGR not off - DTC P0103
  6. #4
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Quote Originally Posted by 2xded View Post
    P0103 is linked to MAF sensor, not to EGR.
    Apr 2013
    boboln4o, "This P0103 diagnostic trouble code (DTC) means that there is a high condition detected in the Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not performing within the normal expected range of the calculated MAF value."
    The EGR is actually muffled. This error (P0103) was before the flash.
  8. #6
    bobolin4o's Avatar
    This error may be set when you have air leaks in the inlet system, or faulty MAF. and so on.
    Any way... here is your ori file with P0103 off. The cks is ok.
  9. The Following User Says Thank You to bobolin4o For This Useful Post:
    2xded (14th July, 2017)
  10. #7
    Apr 2013
    You're right of course, but now the valve is closed, so in hysteresis need to remove the thread through it. If this is not done, then there will be P0103.
  11. #8
    bobolin4o's Avatar
    You are right, but if now P0103 is because of improper EGR off, what will be next when the MAF will gone, or some inlet pipe blowns?
  12. #9
    Apr 2013
    I'm not sure of the correctness of solution from nikka. Now I have another solution, which I will check as soon as the auto returns to me.
  13. #10
    R
    There is 100% working solution U. Need also to close manulay egr or U have another problem.
    Изпратено от моят LG-D855 с помощта на Tapatalk
  14. #11
    kadidiag's Avatar
    Sep 2014
    use this bro
    pass in PM
  15. The Following 2 Users Say Thank You to kadidiag For This Useful Post:
    2xded (15th July, 2017), bugarcek (12th July, 2018)
  16. #12
    Apr 2013
    Quote Originally Posted by kadidiag View Post
    use this bro ...
    Thank you, this is the third solution.
    Quote Originally Posted by nikka View Post
    R
    There is 100% working solution U. Need also to close manulay egr or U have another problem....
    OK. I can check only after the return of the car. In other solutions, the 8167C byte changes, you do not?
  17. #13
    Apr 2013
    The car returned with DTC P0103. I flashed the solution from kadidiag, will watch.
  18. #14
    Apr 2013
    The solution from kadidiag is working!
  19. #15
    Sep 2010
    is possible have the file ori
