bugarcek (12th July, 2018)
There is egr off
2xded (13th July, 2017)
nikka, EGR not off - DTC P0103
boboln4o, "This P0103 diagnostic trouble code (DTC) means that there is a high condition detected in the Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not performing within the normal expected range of the calculated MAF value."
The EGR is actually muffled. This error (P0103) was before the flash.
This error may be set when you have air leaks in the inlet system, or faulty MAF. and so on.
Any way... here is your ori file with P0103 off. The cks is ok.
NO PASSWORDS FOR ANYONE, EXCEPT THE RECIPIENT OF THE FILE !!!
If your PM box is full, clean it right now...
Otherwise, your requested file will be deleted... for ever!
2xded (14th July, 2017)
You're right of course, but now the valve is closed, so in hysteresis need to remove the thread through it. If this is not done, then there will be P0103.
You are right, but if now P0103 is because of improper EGR off, what will be next when the MAF will gone, or some inlet pipe blowns?
I'm not sure of the correctness of solution from nikka. Now I have another solution, which I will check as soon as the auto returns to me.
R
There is 100% working solution U. Need also to close manulay egr or U have another problem.
Изпратено от моят LG-D855 с помощта на Tapatalk
use this bro
pass in PM
The car returned with DTC P0103. I flashed the solution from kadidiag, will watch.
The solution from kadidiag is working!
is possible have the file ori
