skybox v8 problem with webtv
    Jul 2017
    Default skybox v8 problem with webtv
    itry same file on vlc for pc Is working
    but
    I do all step and rename file to WebTV when iwant start channels 0kps
    Oct 2014
    post the last bit of ur script after the password part so I can take a look
  3. The Following User Says Thank You to si111 For This Useful Post:
    plasterer (14th July, 2017)
    Jul 2017
    u mean network ip?
    dasteph's Avatar
    Nov 2008
    north east
    is it a php file or m3u file, both will load into a openbox with success but only a m3u file will show channels on the box as it is a list of web addresses for channels.
    a php file is a web address to a server where the channels stream from, in the url it will have your username and password included.
    Jul 2017
    ****************** idownload it from
    Last edited by digicon; 17th July, 2017 at 04:37 PM. Reason: Please do not post links
    digicon's Avatar
    Your .m3u file will not work on any other device apart from a device that uses VLC as the streams have been encoded to use VLC only.
