Results 1 to 5 of 5
    Mar 2016
    Default Siemens SID803 MAP PACK for posterity
    HI
    FOR ALL
    Added Siemens Sid803 map pack witch axis description
    Peugeot 407 sid803 5WS40167G-T 9656171180 na DK.rar
    If helped press the " Thanks" button.
  2. The Following 45 Users Say Thank You to marcin7091 For This Useful Post:
    armpower (6th February, 2018), artur88 (1st September, 2019), azibi130 (12th August, 2019), beki190 (21st October, 2020), biela (25th September, 2022), BULBG (19th September, 2019), carlosu (31st October, 2018), cosminaec (3rd August, 2023), Desant (21st February, 2018), Dudekpole (6th February, 2023), ENERGIX (24th August, 2021), falcionx (29th December, 2021), FlameFenix (27th August, 2017), gabrilupo (1st October, 2019), galiza (26th July, 2019), grzegorzpilu (14th January, 2021), HFE (20th June, 2022), hjjtz (20th April, 2020), ignac112 (17th October, 2020), inoise (26th July, 2023), ishvedoff (8th December, 2017), jankesp (12th December, 2020), javiere (13th November, 2017), jovanzac (24th September, 2018), kowal162 (6th October, 2018), Krychu12 (18th September, 2022), krzychjarzyna (1st March, 2022), Lacko_1 (26th January, 2021), lukasz12345 (4th June, 2023), maajkii (20th September, 2017), majstorot69 (12th December, 2020), Merzuk (20th November, 2019), Mohssine (13th January, 2021), ondrej (22nd May, 2019), Pablo98 (27th December, 2017), parik (6th September, 2017), radial (1st November, 2019), rickymix34 (25th October, 2018), sami974 (8th September, 2023), slavisac (13th February, 2020), STULEANEC (15th September, 2021), therape (12th April, 2024), wecki2 (4th July, 2019), xptx (28th November, 2017)
  3. #2
    Mar 2016
    Factor, offset
    Driver wish 0.0127 Nm
    TL1 0.03125 Nm
    TL2 0.004 IQ
    Smoke 0.004 IQ
    IQ/Nm 0.004 IQ
    Turbo 0.082918 mbar
    Turbo2 0.0827 mbar
    Rail press 0.030517
  4. The Following 6 Users Say Thank You to marcin7091 For This Useful Post:
    azibi130 (12th August, 2019), Darki10 (27th January, 2021), galiza (26th July, 2019), hjjtz (20th April, 2020), Starkin (6th November, 2017), STULEANEC (15th September, 2021)
  5. #3
    Feb 2016
    Hi marcin,
    I wanted to know if your mappack is good for my ECU.
    I have the same car same ECU but 5WS40167H-T
    HW: 965504480
    SW: 965834080
    And something else. I have found somewhere a a2l file for the SID803A (po242031.a2l). Do you think I can use it for the SID803?
  6. #4
    Aug 2016
    Belarus
    Quote Originally Posted by Starkin View Post
    Hi marcin,
    HW: 965504480
    SW: 965834080
    a2l file from the SID803A does not fit to SID803
    it's a completely different ECU!
    mappack it is necessary to look correctly determine the cards, because the other software maybe not everything will show it correctly
    if you dumped it could be immediately tell whether it suits you or not, and so only fortune telling
    Feb 2016
    OK.
    I see what you mean.
    I dumped your mappack over my file and it seems that it finds the same maps as yours.
    At least the first ones I managed to take a look.
    About the a2l file, I have seen in another forum that someone suggested to use it on the 803 even though it is from 803A.
    Maybe he is wrong, maybe he uses special offsets.
    I know they are different ECUs. Mine is 449 KB and the 803A is 2048 KB.
    And in another forum I have found an invaluable thread about the SID 803, where the guys have found many maps and offsets that are the same as yours.
    I can post you the address of the forum if you like.
    Finally, where can we find a damos for the SID 803?
    I have searched all over the Internet, but no lack.
    And something more.
    What is the map(s) for the DPF?
