Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Question Dacia Duster 2015 Mileage correction
    Hello mates,
    I have a Dacia Duster 1.5 dCi year late 2015 to correct mileage.
    Dashboard is part (248106459R --- MR V2 KM) and has MCU MB96F6A6 without external eeprom.
    Has anyone read this MCU ? I have X-Prog, Smok JTAG, UPA, UPA-S, Orange, ETL.
    Anyone has already tested any of this ?
    I think Smok can read this MCU, but I search any feedback or experience...
    Is it possible edit mileage by dump ?
    Another problem is the ABS Pump.
    It does not have eeprom 95640.
    I think it will be on the other side of the pcb.
    ABS part number is 476606440R.
    Can anyone help me with pinout please ?
    I attacched a picture of ABS.
    Thank you for help
    Bests
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    What numbers are on the 8 pin eeprom in picture and have you got a picture of other side of pump
    Neither is an eeprom.
    First component is A1040A - Can Bus Transceiver
    Second component is 4254GA - Voltage Regulator.
    Do you means the other side of pcb ?
    How can I take a picture of the other side ?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Show whats on other side of abs module
    How can I remove the pcb from abs pump ?
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Undo 4 x torx bolts
    Ok, tomorrow I will remove the 4x torx and then can I remove the pcb ?
    Thank you
    This is the other side of ABS pump.
    I think the eeprom is the TSSOP component marked as ST 528D4.
    What type of eeprom is it ?
    Bests
    Mar 2017
    Colombia
    St 528D4 = M24256 256Kbit.(32)......
    Read . Atmel AT 24C256
    WINNER THE LOSER
  10. The Following 2 Users Say Thank You to automotrizVIP For This Useful Post:
    paskuale (22nd July, 2017), rtbdiagnostic (6th April, 2021)
  11. #10
    Quote Originally Posted by automotrizVIP View Post
    Are you sure ?
    On another forum I read that 528D4 is 95128.
    I ask to be sure, I don't want to mess the car
    Thank you
  12. #11
    This is i2c so read ad m24256. Take the pdf chip and look at connections.
    Wysłane z mojego SM-J320FN przy użyciu Tapatalka
  13. The Following User Says Thank You to yokazik For This Useful Post:
  14. #12
    Ok, tomorrow I will read the eeprom as 24C256 and post the dump here to correct.
    Thank you mates for help me
    What about MCU MB96F6A6 in the dashboard ?
    Is it possible to read and correct by dump ?
    Bests
  15. #13
    For dash reprog i use smok.
  16. The Following User Says Thank You to yokazik For This Useful Post:
    raptureready (26th July, 2017)
  17. #14
    carbandit's Avatar
    bonnie scotland
    Yea smok does this version with no eep
  18. #15
    But I don't have SMOK UHDS tool
