Results 1 to 15 of 28
    Jul 2013
    yorkshire
    Default citroen c1 all keys lost
    Just looking for a bit of info on this. Customer had only one key that is lost, and car is locked. My usual locksmith tells me he cannot help!!!! Tells me dashboard needs to come down etc. Can dealer supply new key? or is that too easy. What tools needed if i can get in to it. Thanks for any info. autoden
    szengen's Avatar
    Jan 2017
    Mechanical key peugeot citroen, immobox toyota aygo peugeot 107 citroen c1, eeprom 24c04, tansponder tiris 4D id 70
    rob h's Avatar
    May 2011
    Just pull the top off the door open.
    Use some sort of wedge.
    Then reach for the doorhandle with a rod. Preferble a bit curved.
    Or coathanger.
    Plenty of vids on Y-tube.
    The immo box is mounted on top of the steering collum.
    It can be reached without removing the dash cover, if you know what you are doing..
    And remove a door cilinder, to dissamble. You need to decode this.
    What year is this C1?
  4. The Following User Says Thank You to rob h For This Useful Post:
    doctore (20th September, 2017)
    Jul 2013
    yorkshire
    Ye sorry its 2006. Can it be decoded by carprog?
    rob h's Avatar
    May 2011
    Yes, carprog can do Aygo.
    Aygo 107 and C1 or the same.
    Check Y-tube
    Creating keys for a Toyota Aygo (2005 - 2013) using Touchclone.
    Lost keys
  7. The Following User Says Thank You to rob h For This Useful Post:
    szengen (20th July, 2017)
  8. #6
    Jul 2013
    yorkshire
    Sorry to be a pain, how to decode with carpog. Can it be done by OBD or on bench. More info please as im no key man.
  9. #7
    rob h's Avatar
    May 2011
    No tool can do all keys lost by obd.
    Add key by obd, if you have a working master key is possible.
    You could watch the touchclone video first!
  10. The Following User Says Thank You to rob h For This Useful Post:
    autoden (20th July, 2017)
  11. #8
    Apr 2016
    uk
    Quote Originally Posted by rob h View Post
    Hi Rob
    Got the same issue on a 107 2007.
    Please can you explain better what do I have to do?
    Read 24c04 from immobox and then?
    I have tango if it's easier.also got carprog clone 8,skp 900, x300 xtool..
    Inviato dal mio HTC One utilizzando Tapatalk
  12. #9
    lion0304's Avatar
    Oct 2014
    Hi Rob
    Read 24C04, Tango should do it, but my case use Tag key tool fvdi 100%
    Immobox: 89780-0HXXX
  13. The Following 3 Users Say Thank You to lion0304 For This Useful Post:
    comizelu (20th September, 2017), doctore (20th September, 2017), TERMINATOR1000 (22nd September, 2017)
  14. #10
    Duracell2's Avatar
    Apr 2017
    Here I will explain how I do it. Other locksmiths may use other methods.
    Step by step guide:
    1) Smash the driver window
    2) Open the car
    3) Take out the ECU
    4) Make immo off
    5) Put ECU back
    6) Break ignition lock
    7) Short the wires
    8) Drive the car to shop and repair the driver window
    Easy.
    Please hit the rep & thank buttons if this post was helpful!!!!
  15. The Following 2 Users Say Thank You to Duracell2 For This Useful Post:
    CaioW (20th September, 2017), comizelu (20th September, 2017)
  16. #11
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by Duracell2 View Post
    Step by step guide:
    2) Open the car
    3) Take out the ECU
    4) Make immo off
    5) Put ECU back
    7) Short the wires
    Easy.
    where did you see that the locksmith service
    breaks the windows and cuts the wire
    and fires the car with the immooff and then everything fixes it
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  17. The Following 2 Users Say Thank You to doctore For This Useful Post:
    lion0304 (20th September, 2017), nenadgorgi (20th September, 2017)
  18. #12
    Feb 2014
    Step by step guide:
    2) Open the car
    3) Take out the ECU
    4) Make immo off
    5) Put ECU back
    7) Short the wires
    Easy.
    You are not serious! Right?
  19. The Following User Says Thank You to autoTkey For This Useful Post:
  20. #13
    Apr 2016
    uk
    Is it possible Immo of ?
  21. #14
    Apr 2016
    uk
    Quote Originally Posted by doctore View Post
    Something like Bonnie and Clyde..??
  22. #15
    Apr 2016
    uk
    Step by step guide:
    2) Open the car
    3) Take out the ECU
    4) Make immo off
    5) Put ECU back
    7) Short the wires
    Easy.
    Sorry man
    Can't do that.better leave the job to someone else.
    Immo off only temporary solution.
