VIRGIN ECU DCI 130 SCENIC 2
Results 1 to 10 of 10
    May 2016
    manosque
    Default VIRGIN ECU DCI 130 SCENIC 2
    Hello who can make me a virgin on renault scenic 2 DCI 130 SCENIC .zip
    Apr 2017
    EU
    Give more details ecu number .....
    IF I HELP Don`t forget to use Thanks button and reputation
    I give negative reputation for people who even a THANKS not give for received helps!!!
    New Users Don't PM me for radio codes or similar, you will not get any answer...
    BR foks025
    May 2016
    manosque
    a2394.jpgthanks
    Apr 2017
    EU
    Hello ,
    here your file try it and post result
    Good luck
    BR foks025
  5. The Following User Says Thank You to foks025 For This Useful Post:
    OMAR835 (21st July, 2017)
    Apr 2017
    EU
    now it should be OK
    BR foks025
    May 2016
    manosque
    Hi the friend i have to load the file an error verification block a l write once put on car seeing fixed red :? votre sant?:
    Apr 2017
    EU
    The same password
    BR foks025
  9. The Following User Says Thank You to foks025 For This Useful Post:
  10. #8
    May 2016
    manosque
    Hello friend tjs same red light fix
  11. #9
    Apr 2017
    EU
    I went home Virgin, you have to encode the injectors, I do not know if he will himself
    The same password
    BR foks025
  12. The Following User Says Thank You to foks025 For This Useful Post:
  13. #10
    May 2016
    manosque
    SALUT THE FRIEND I AM ONE CAN GIVE NEWS I HAVE THE CALCULATOR WITH THE VIRGIN; MORE D STARTING AFTER REPROGRAMATION SERIAL NUMBER AND INJECTOR DEFAULT ON BOX PREHEATING AND INJECTOR NO STARTUP. AN IDEA???
