where you from???
Hi.
Need info about Volvo dashes and Abrites Clone. (Languages)
Tested:
Volvo XC90, 2003, 68HC912DG128A_3K91D
Volvo XC90, 2005, MC9S12DG128B_0L85D - (after need disconnect battery)
Volvo XC70, 2003, 0L85D
Volvo S80, 2002, MC912DG128ACPV_3K91D
Volvo V70, 2001 - No connect! Why, I dont know...
need info about XC70 2008, V70 2009.. ?
and others Volvo 1997-2016
Clone Abrites - Is it safe?
How do know what the MCU mask? (without dash removing)?
With which device can I change the Radio language? (Smok only dash?)
Thanks!
where you from???
Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
oppp....you have nice women in Latvia !!! see this ,for older is o.k,,,for new after 2008 dont work !! tested by me....
FVDI (Volvo V4.3) like XC70 2008,V70 2009 .. not to do.
Reed and write eep. good. Reed flash good Write flash 10% good 90% crash.
What mask proz. have?We dont now ,just put correct car year and enaugh .
Good FVDI or not ? Same sulution working good same not .More experience(Not this bad tool,bad day or......) if you want do job with this tools like FVDI.
Language change not only Smok.
Good luck.
the dash is damaged or not possible to reflash?
Yes ,dash not damage,but reflash by Fvdi after crash not posable.But befor crash, FVDI write save original in volvo file.Take original use bdm programmer or Smok by OBD2 and rewrite.
Aivis3 (22nd July, 2017)
year of the volvo??model ??
Still a question about tools for Volvo dashboard and ICM
What are the best / cheapest tools?
The cheapest thing I have found is - I/O Terminal Volvo tool (Volvo tool: 500EUR + Hardware: 100EUR)
http://ioterminal.com/?page_id=928
SMOK: (Very expensive!)
Interface Multitool UHDS - 130 Eur
Dash - Volvo change KM by OBD (VOP1) - 480 Eur
ICM - EU0018 Volvo Display change language by OBD - 320 Eur
uhds work perfect with dash,can write flash without car direct by cluster plug,but i don't have display option yet .2001 volvo v70 with small motorola mcu work by obd 100%
Good guys, I rehabilitate this topic, to see if any of you can help me
here my base post
https://www.digital-kaos.co.uk/forums/showthread.php/745008-Flash-volvo-s40-v50
the question that in my case unlike this video the board was off
Dashboard cpu mask 0L85D
now with fvdi impossible to reset the flash, only allows a small portion of the
you know with what tools I could write via bdm, assuming I can find the connections for the board?
I was looking to use carprog, but I only see CEM documents
Do you know where I can get the plate connections?
Greetings and thanks
If help is useful thanks+rep
when dim not ressets just use dice for resset
Talleresmalaga (26th May, 2019)
