Results 1 to 9 of 9
    Jun 2017
    Default Renault Kangoo 1.4 immo off problem
    Hi ,
    My car wont start it looks like it cant read key code. Red lamp is blinking and it should not blink.
    I am trying to do immo off .
    I have read ECU using KESSV2 so here is original read file. In attachment
    It is Renault Kangoo 2000yr 1.4 Gasoline 5gear manual Siemens Sirius 32 8200061272
    Here is a photo of ECU http://imgur.com/wBA16cp
    Any help is appreciated .
    dominik.m's Avatar
    Jun 2009
    POLAND
    Need know- 8 or 16valve and with or without AC .
    Jun 2017
    Quote Originally Posted by dominik.m View Post
    8 v without AC
    Dec 2015
    sirius32 1.4 8v no AC.rar
    Try this dont forget to cut pin58
    just resolder the chip on the key board
    Jun 2017
    Quote Originally Posted by aandroma View Post
    I will try . Is it ok if i write it with kess v2 (obd2) ?
    Quote Originally Posted by albertros View Post
    What do u mean ?
    I am doing this first time, i dont understand what i have to do.
    Can u explain please ?
    belgrade,serbia
    kangoo ecu read off original.rar here you are,write this file and cut wire on pin 58 on engine ecu connector
    What do u mean ?
    Open the key
    find the rectangle large chip
    resolder legs very carefully
    check continuity on aerial, copper coloured long part
  9. The Following User Says Thank You to albertros For This Useful Post:
    Pyromaniak (26th July, 2017)
  10. #9
    Pyromaniak's Avatar
    Aug 2015
    ~~~~ing CZECH
    What do u mean ?
    Open the key
    yes, in most cases is problem here I have lot of renault repair with this method. Most peoples try if not work button in key much power to press it. Pcb bended and chip lost contact with pcb.
    My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
    My help not for free, press THANKS and REP, for make me HAPPY
    im not using passwords, my work is for this forum and members free
