    Jun 2009
    Default Modify BSI Partner
    Hello, could you please help me with this BSI with partner 95160, the board with 95020 is already modified. I need to reset the BSI. I try to modify from position 112 to 135 but the mileage was not modified, it may be you have to change from 10C up to 135? Thank you in advance for your help.
    here is your file
  3. The Following 2 Users Say Thank You to nikz For This Useful Post:
    guillermoc (21st July, 2017), richiebb (21st July, 2017)
    Jun 2009
    Thanks for your answer, I see that you have modified from 10E to 135 until here understand but then for what are the modifications in lines 195, 1A3 and from 520 to 527?
    I modified at $10e- $125
    This is enough
  6. The Following User Says Thank You to nikz For This Useful Post:
    Jun 2009
    You're right my friend, I compared with another data of the same car so the difference, thank you very much.
  8. #6
    Jun 2009
    It works perfect, thank you very much.
